quick fix - tire noise
neilson
My infiniti G37 10 is going through a rough phase. Right now I am hearing tire noise and need a quick solution since I will be having guests right after Eid and cannot deal thoroughly with the issue right now. Can anyone advise some good techniques to reduce the tire noise?
Jack up your car from the tire you think is causing the noise. check the tread area to see if your tire is worn out. worn out or
unevenly worn out tires from the front and rear can cause an unpleasant noise. If you know which tires is causing noise, try
changing the tire if you have a spare. see if the noise continues... good for a quick fix?
