engine is overheating
take your car to a mechanic and ask him to check the following
a water pump if it is leaking
b cooling fan if it is working
c thermostat if it is working which consists of valve,housing and valve returning spring
d If there is a leak in the radiator hose
e hose clamps are damaged
f radiator cap is broken
g if there is sufficient coolant.
h Catalytic Converter
any of these will be faulty and responsible for overheating.
