i cant install the ignition coil back in.
If you cannot get the ignition coil to go back into place, then you should bring it to a shop. It you continue to force it and try to "make it fit", then you are likely to cause even more damage. In the end, it will just cost you time, money, and a headache. Just bring it to a shop or dealership and let them do it properly.
  • 11 months later...
