Oil leak?
khandelwal
Hi aman,
Do you have some basic knowledge about gaskets and seals? If so then you might be able to look into the problem yourself. You need to drain the oil, replace an oil filter and fix the valve cover gasket. You need to keep a look out for any signs of leaks while you are in the process of replacing and changing gaskets. And remember to warm up the engine a little before you begin so that the oil draining process is easier. If you have no idea what I am talking about then I guess you need to take it to have it checked ;)
