Battery and headlight
I suppose you must have left the headlights on someday when your car was parked. If you do that, the headlights suck up lot of power from the batter, and thus the battery goes down. The reason why the headlights are dim is because of the low power in the battery. And may be, the battery in your car is really old and thus its facing trouble with recharging. Also, the alternator and charging system troubleshoot can be one of the reason for the same. Get your battery checked. I suppose you need to replace the old battery with new one.
