Engine Heating in Desert
Wel there can be many reasons:
Radiator broken: If the radiator of your car is broken then the engine heats up very fast
Low Coolant: If the engine persist low coolants then they are not enough to decrease the temperature in the engine.
Electric Fan cooling: Or may be the electric fan cooling is not working in your car.
Engine overheating is always bad, so you get your car checked in the service centre asap.
  • 3 weeks later...
