micheldxb Posted September 7, 2012 Report Share Posted September 7, 2012 how is the timing belt changed mine is going to get changed next week so would like to know how its done for cross reference. thanks Link to comment Share on other sites More sharing options...
wilson Posted September 10, 2012 Report Share Posted September 10, 2012 found this video. Link to comment Share on other sites More sharing options...
harryak Posted November 15, 2012 Report Share Posted November 15, 2012 http://www.wikihow.com/Change-a-Timing-Belt is a link that i have found that has instructions on how to change the timing belt. Link to comment Share on other sites More sharing options...
micheldxb Posted January 3, 2013 Author Report Share Posted January 3, 2013 wilson wrote: > found this video. > thanks Link to comment Share on other sites More sharing options...
waterboy Posted February 24, 2013 Report Share Posted February 24, 2013 whats the difference between timing belt and timing chain? Link to comment Share on other sites More sharing options...
micheldxb Posted March 21, 2013 Author Report Share Posted March 21, 2013 As far as i know timing belt needs changing and timing chain needs servicing. now a day belt are used not chains. Link to comment Share on other sites More sharing options...
bradt Posted June 2, 2013 Report Share Posted June 2, 2013 Timing chain or the timing belt are same part of engine of all cars that synchronizes the timing of the engine. This transfers the power of crankshaft to the cam shaft which activates the valves, thus providing air and fuel to engine cylinders. Both timing chains and timing belts perform the same job of delivering the power based on engine timing valve opening and closing. In 70’s timing chains were popular and most automobile makers made use of these chains. In 90’s timing belts made out of hi quality rubber became popular, but now again it is timing chains that are being preferred by manufacturers. What are the main difference between timing chain and timing belt, and what their features and pros and cons are: The real difference between a chain and a belt is what you would expect with the materials with which they are made. A chain is made of interlinking metal pieces, is heavier, stronger and makes more noise. It is also longer lasting. However, a timing belt is less expensive, is serviceable, less complex than a chain, but needs to be replaced more often than a chain. It is car manufacturer’s perceived efficiency that makes them go with a timing chain or a timing belt. You can hear the noise made by the chain when the car is running but the timing belt rarely makes any noise. Link to comment Share on other sites More sharing options...
micheldxb Posted June 25, 2013 Author Report Share Posted June 25, 2013 well explained brad. Link to comment Share on other sites More sharing options...
