Sign in to follow this
davida
Jostling around
Hello, recently i have noticed that my car has started to jostle around while i am driving. There seems to be a problem with the suspension. The problem is not over the top at the moment but obviously being an owner for a long time i can feel the difference. What can be the cause? Thanks everyone in advance. PS. I have an LS400.
So basically your driving does not seem to be smooth anymore correct? if thats the case then it is probably a problem with the suspension. When a car jostles ... its specifically used to describe a problem with the rear struts. Have any idea about them?
Well they are supposed to keep your car on the ground. when your car does the opposite it means that the rear struts have worn out and they need replacing. They help you ride bumpy roads and slopes etc.
