toheer Posted February 10, 2011 Report Share Posted February 10, 2011 the lining inside the sunroof needs to be repaired how do i remove the entire headliner to get it repaired. Link to comment Share on other sites More sharing options...
faheem Posted February 15, 2011 Report Share Posted February 15, 2011 You can carefully remove sunroof without removing headliner. some shops will say you need to remove the whole roof headliner to get sunroof out. but you dont. if you can remove the sliding headliner, then the glass roof. in order to pull out the cables, you need to loosed the sunroof motor so it's not engage with the cables... hope this help.. Link to comment Share on other sites More sharing options...
