OIL LEAKING
Oil leak and gasket are associated to each other.
You didnt mention which oil is leaking.
If engine oil then crank case gasket, engine housing gasket, chamber gasket are gone and need change.
If gear oil then its lot easy and only one gear gasket to doubt.
