EPC issue
EPC (Electronic Power Control) is kind of check engine light. It probably detected something was wrong. You may want to see a dealer/shop that can pull the actual trouble codes to see what is wrong. It is probably a sensor such as MAF.
MAF is the Mass Air Flow sensor. When it goes bad, the engine loses power and runs strangely.
I only suggest as a (common, though) possibility.
  • 4 weeks later...
