parekh Posted April 15, 2012 Report Share Posted April 15, 2012 Hi Everybody, this is Parekh. I drive 2005 ML 500 with 71000kms. Recedntly got the brake warning sign on dash, so i got the new brake pads changed today. Original ones but from one of known workshop in shj. After installing and restarting the car many times still brake pad warning light is still on. Does that mean that my old pad was fine too, and i changed these to new invain? Anyone knwo why such problem happen. Dont wanna go to gargash for 2005 model, as it will be very expensive for me. Awaiting your guys support, appreciate it. Link to comment Share on other sites More sharing options...
sonu Posted April 22, 2012 Report Share Posted April 22, 2012 Brake pad has small sensor attahced with the two wires on each brake pad. As brake pad wears the sensor rubber part also wears and when brake pad finishing point starts brake pad sensor metal wire start touching the brake disc giveing brake pad light inside. You should get the brake pad sensor and also change it to stop this light. Link to comment Share on other sites More sharing options...
