My S500 Is having vibration
Hi,
I own a 2001 s 500 and i am facing vibration while throttling and knocking while it's parked. i have got it checked through a mechanic and they said me the pulley is broken get it replaced but i don't think that can be the case as i feel it while the car is running even. Can someone suggest is it the pulley alone or can be a mixture of issue like Drive shaft, Pulley & Plugs or coil.
thanks,
Naved
Its too hard to advise w/o seeing the real vibration. If its body vibration while idle then it could be engine mounting. If its engine hesitation and pulsating vibration at regular frequency then it could be coil or spark plug. If its vibrating at certain specified speed only like 80-100 then it could be wheel balancing issue. If its vibrating while picking up car (accelerating only) then it could be air flow meter, air flow meter sensor or dirty air filter. I am not sure where the pulley is associated here. Better get a second opinion from decent garage w/o sharing the pulley part.
