duttg Posted August 11, 2013 Report Share Posted August 11, 2013 Greetings folks!! I really hope the experts/car enthusiasts on this forum can help me out. I have a problem with my 2004 S350 Mercedes Benz. After starting the engine when I try to shift the gear from P to R or other gears, I have to use extra force to move the gear stick. It is called the selector lever in the manual. I do not think the problem is due to low transmission oil as there is no indication of any malfunction on the dashboard. This is the most expensive car I have ever bought and I absolutely love it. I hope this is not a major issue. Please advise. Link to comment Share on other sites More sharing options...
bensondxb Posted August 11, 2013 Report Share Posted August 11, 2013 hi dutt, Umm... once the lever is out of P does it shift ok down the gearshift gate & back up to P again? Just a hunch I have ... Link to comment Share on other sites More sharing options...
mufti Posted August 11, 2013 Report Share Posted August 11, 2013 Hi guys, Not to sound too technical but ... This is a common problem on the S Class which occurs because of the P lock solenoid in the gearshift module - sadly the module is only available as one complete unit and must be replaced as the complete gearshift. It also requires coding after it is fitted in. Link to comment Share on other sites More sharing options...
duttg Posted August 11, 2013 Author Report Share Posted August 11, 2013 thanks for the help guys ... @ benson Yes, once the lever is out of P there is no problem whatsoever. Thanks for your time. @ mufti... Any idea about the costs? Thanks. Link to comment Share on other sites More sharing options...
vijays Posted August 11, 2013 Report Share Posted August 11, 2013 Hey buddy ... have the car checked on a diagnostic tool for fault codes. i wish i could help you more with this problem but i guess this is the only way out! Link to comment Share on other sites More sharing options...
alikhalil Posted August 14, 2013 Report Share Posted August 14, 2013 My experience tells me that it could be a problem with the stop lamp switch not sending a signal to the gearshift module although usually when this fails the lever does not shift out of P at all. Worth a try. Link to comment Share on other sites More sharing options...
hemant Posted October 5, 2013 Report Share Posted October 5, 2013 Which brand of transmission oil are you using? Link to comment Share on other sites More sharing options...
duttg Posted October 5, 2013 Author Report Share Posted October 5, 2013 Amsoil or Redline. I thought those were the best ones available? What do you suggest? Link to comment Share on other sites More sharing options...
jamal Posted October 5, 2013 Report Share Posted October 5, 2013 Hi guys!! Very informative post ... just a quick question. i recently heard that MB says that the transmission fluid does not need to be changed during the entire life span of the vehicle. is that true?? Link to comment Share on other sites More sharing options...
bully Posted October 5, 2013 Report Share Posted October 5, 2013 Totally insane man. Who told you that? You should change the fluid along with the filter every forty thousand miles/sixty thousand kilometers. Link to comment Share on other sites More sharing options...
