Sign in to follow this
edward
Volume Up and Down
Whenever i turn on the navigation in my car, suddenly the volume of the audio system goes down and it remains in the same level till the navigation is on. This issues bumps me out as i need both my audio system and navigation to work properly without disturbing the volume of the music. Did anyone faced such a problem. And if yes, then what you did for the same? Please suggest me as I am really annoyed because of the same.
There can be possibility that the navigation and audio system are interconnected and so may be the wiring.
Second probability is navigation voice command system is over ruling the audio system, so try to switch off the voice command direction system of your navigation (if some option is there in settings) and see if it helps.
