Radiator water is becoming empty
mahbub_ma
In my Nissan TIIDA,2007 model, radiator is becoming empty. As I checked it with a local mechanic, he found no leak in radiator. Whether I found when I keep the car parked and engine is switched on, drops of water is coming from the middle of front 2 wheels. Can anybody give me the solution?
Test the car running, but AC switched off. Those drops must be from AC condensation water. So if you see the drops w/o AC then there is some water line leak and your mechanic need to try harder to find them.
DO NOT IGNORE this issue as car engine running for less than 2 mins w/o water can fry your whole engine and you have to buy new engine.
