my mini 2007
kevin
hi guys ... I have a mini and the doors just seem to have stopped opening lol
What I mean to say is that they seem locked .. MOST of the times they dont open so i have to roll down the windows and open them from the outside. If they please, they do open for me once in a while but thats very rare hence I am getting concerned. Did not expect something like that from a mini! help needed!
Hiya kevin,
Although I don't have a mini but to be sure try spraying WD40 on the door gaps - this will lubricate the area and make door that the problem is not the doors being jammed ... rest you can also have your door latches checked, they might not be working properly.
  • 5 years later...
I have the same issue with my mini and it’s cause the lock mechanism is at an angle from inside the door. It’s funny the way I found the issue and found the solution for it. Plus in a way I know the trick and it clearly makes my mini only under my control. No1else would take it....🤓
