tobye Posted October 6, 2012 Report Share Posted October 6, 2012 My mechanic says that the O2 sensors on the exhaust pipe need to be changed but i dont know why when i just went for getting the fuel filter changed as the car was giving bad fuel efficiency . My question is if i change the o2 sensors do all of them get changed and what are their functions. Link to comment Share on other sites More sharing options...
antee Posted October 7, 2012 Report Share Posted October 7, 2012 the sensor makes sure that the air and fuel is mixed in correct ratio if the air is more then the fuel quality will decrease and if the air is less then the fuel will leave residue that will harm the car again and exhaust too. Link to comment Share on other sites More sharing options...
franknic Posted October 14, 2012 Report Share Posted October 14, 2012 O2 sensor may be a small part of the car that is usually ignored but if not changed on time it could cost you your car's engine. Link to comment Share on other sites More sharing options...
tobye Posted January 10, 2013 Author Report Share Posted January 10, 2013 waited for service and got the sensors changed. Link to comment Share on other sites More sharing options...
mayurs Posted January 30, 2013 Report Share Posted January 30, 2013 very important to check O2. if there is black smoke then it means O2 sensors need changing. Link to comment Share on other sites More sharing options...
tobye Posted February 11, 2013 Author Report Share Posted February 11, 2013 thanks Link to comment Share on other sites More sharing options...
amo Posted March 7, 2013 Report Share Posted March 7, 2013 which engine is used in Nissan Armada ? Link to comment Share on other sites More sharing options...
tobye Posted May 27, 2013 Author Report Share Posted May 27, 2013 The reason you didnt get your answer yet is because you didnot create you own separate post. Link to comment Share on other sites More sharing options...
blackArmada_DXB Posted July 31, 2013 Report Share Posted July 31, 2013 The thread has been created long ago, but I will give my inputs on this anyway. If there is no Check Engine Light (CEL) then the O2 sensors are probably working fine. A CEL doesnt always mean that O2 sensors need to be changed. You should hook up a diagnostic tool to the OBDII port and get the DTCs and then troubleshoot and solve the error. Would have saved you $$$. Link to comment Share on other sites More sharing options...
