Squeaking when i leave brakes
tobye
Since few weeks i am hearing some strange squeak when i press the brake and car is about to come to halt and when i leave the brake car squeak as if some car braking springs is crying. Its not a brake pad squeak as it comes while braking and this coming when i leave the brakes. Any good advise is highly appreciated. Thanks guys.
  • 1 month later...
If its not squeaking while braking and only when you leave the brake means suspension needs a proper check. As while braking car tend to lean forward and when you leave the the brake it goes back to its standard height. While going back to standard height springs or shock absorber make squeaking noise as an indication of telling you that they need change. More than often its springs that fails first than shocks. Better get it check and second opinion to be 100% sure before making this expensive repairs.
  • 2 weeks later...
  • 2 weeks later...
