rear washer fluid
amite
Hello amit,
This is a pretty common problem in generally all cars at some point. Have you tried filling up the washer fluid's reservoir with more fluid? If it does not work then you can try cleaning the nozzles and the hose for the rear wiper ... If all fails then you can try this troubleshoot method with easy steps ... its all visual so you should not have a problem ... hope it works out for you
http://www.nissandubai.com/xterra/rear-washer-fluid-t396.html
hey there ... followed the method on the site and it worked like a gem!
i didn't even have to spend a dime .. and trust me its usually never like that.
Even for the smallest problems i have someone look at it but this is great ... kinda boosted my self-esteem too
You're the man!! n thanks carnity!
