ameens Posted February 24, 2014 Report Share Posted February 24, 2014 Hi Everyone My name is Ameen. I am facing problem in my Armada. The gear change is not smooth as it was before. My car recently had an accident and repaired in nice workshop. Can anyone tell me why is this happening?? Link to comment Share on other sites More sharing options...
rattan Posted February 25, 2014 Report Share Posted February 25, 2014 May be the oil supply is not proper in the gear box, That is why you experience roughness while changing gears. Start with changing the gear oil and gear oil filter to eliminate the dirty gear oil probability. If still same then you may consult the expert and get it checked if the oil is smoothly processing in the gear box. Link to comment Share on other sites More sharing options...
carguy Posted August 18, 2014 Report Share Posted August 18, 2014 May be the level of transmission fluid is very low. That leads to the roughness of engine. Link to comment Share on other sites More sharing options...
