handbreak and oil light is on
  • 3 weeks later...
Check all the fuses, it may be half burnt or blown already and son slight contact it get lit up.
If still same then change the oil pressure sensor as its cheap and easy to fix next to oil filter. Its quiet common culprit. For hand brake light, i dont know and i hope someone else will help here for that.
  • 5 weeks later...
