harfaz Posted May 10, 2011 Report Share Posted May 10, 2011 i need a head gasket change and my question is that as they will be dismantling the engine and its a big job so if there are other things that need to be changed Link to comment Share on other sites More sharing options...
williamn Posted May 18, 2011 Report Share Posted May 18, 2011 Let mechanic check the component and comment about timing belt condition, timing belt bearing condition, water pump, oil pump and other small bearings around. I hope mechanic change all gasket while closing the head as its strongly advisable to change all gasket around wile changing the head gasket. Link to comment Share on other sites More sharing options...
harfaz Posted June 14, 2011 Author Report Share Posted June 14, 2011 thank you!!!!! Link to comment Share on other sites More sharing options...
