intake manifold flap is broken
when hearing a whistle like noise from the engine i had to take to a workshop and the mechanic has informed me that the flap of intake manifold is broken and he said that the the intake manifold has to be changed altogether
is that true? cant i just get the flap replaced?
For sure you dont need to change the whole manifold as its very expensive. Instead go to BM road spare part guys and ask them for flap assembly in Intake manifold. They will get you the that small bit in which flap is already drilled and bolted. Your mechanic need to remove the whole manifold and replace that part.
May be find some other (not lazy) mechanic to do this job.
