Coolant hose leaking
it is always better to replace the bad hose which is leaking with a new one as soon as possible. If you will not replace the leaky coolant hose, the other hoses will also ten to fail soon. also remember,when you replace the the bad hose, please check the other hoses as well in order to make sure that they are working fine.
  • 2 weeks later...
Any kind of leaking is bad of the car. Leaking generally is a result of low coolant of low oil level. And parts which are involved in the leaking are generally not fixable, One needs to replace them all in order to avoid any sever problem. With the coolant hoses, it creates internal leaking sometimes. To avoid that, replacement is the best option.
