panchaal Posted February 29, 2012 Report Share Posted February 29, 2012 what is the way to check if timing belt needs changing. is it depending on th km or years? Link to comment Share on other sites More sharing options...
milane Posted March 24, 2012 Report Share Posted March 24, 2012 It only depends on Kms, and better not wait for symptoms as if you wait that long im afraid damage will be already done. In porsche its closer to 100k km, refer to your owners manual see if its nearing that kms. Link to comment Share on other sites More sharing options...
Nehmaiz Posted April 2, 2012 Report Share Posted April 2, 2012 Guys would really be helpful if the person who replies would double check their information first before replying... Porsche Boxsters do not run a rubber timing belt, they have an internal timing metal chain that usually does not require changing. porsche 4 cylinder engines found on 924s,944s,968s have a rubber poly ribbed belt used to time the valve opening with the car's engine rotation. so my friend you don't have to worry about your boxster's timing chain. ###PORSCHE NUT EXTREME### Link to comment Share on other sites More sharing options...
hatim Posted April 2, 2012 Report Share Posted April 2, 2012 Good point made, Nehmaiz. +1 Link to comment Share on other sites More sharing options...
