leshesh Posted June 15, 2012 Report Share Posted June 15, 2012 if i get the timing belt changed what other parts are changed with it OR what other parts can i get checked to get it changed as the Mechaninc says that the labour cost is high so i thougth its better if i can get other parts changed too Link to comment Share on other sites More sharing options...
markfox Posted July 5, 2012 Report Share Posted July 5, 2012 i suggest just change what you have to that is the timing belt as of now and also check the baring if it needs changing. dont over think and if you tell your mechanic that you want to change other things then they may forcefully change other parts. let the mechanic see your car and see what he suggests. Link to comment Share on other sites More sharing options...
leshesh Posted January 13, 2013 Author Report Share Posted January 13, 2013 mechanic was advising me to just change the timing belt. Link to comment Share on other sites More sharing options...
sanat Posted February 10, 2013 Report Share Posted February 10, 2013 how much have you paid for changing timing belt. Link to comment Share on other sites More sharing options...
leshesh Posted February 18, 2013 Author Report Share Posted February 18, 2013 1000 after discount 850 i had changed the brakes and even the spark plugs so for just timing belt before he quoted me 1000 and after all this job he came down to 850 Link to comment Share on other sites More sharing options...
fine Posted March 28, 2013 Report Share Posted March 28, 2013 Is changing the timing belt a long time consuming thing? Link to comment Share on other sites More sharing options...
leshesh Posted April 6, 2013 Author Report Share Posted April 6, 2013 what do you mean by long time consuming thing. Link to comment Share on other sites More sharing options...
rudh Posted June 4, 2013 Report Share Posted June 4, 2013 i have changed the timing belt and even changed the foundation and the fuel pump. this if changed separately at different time i would have spent a lot but in total i only spent 1500. Link to comment Share on other sites More sharing options...
leshesh Posted June 25, 2013 Author Report Share Posted June 25, 2013 well you have been lucky then rudh. Link to comment Share on other sites More sharing options...
