raoofh
turn signal lamp
Front side indicator is easy as its near to headlight cover in front hood.
Rear one needs little tool to open, better get it done with mechanic. WHich side it is?
This is not a big problem, but you should definitely sue the help of a mechanic because you can ruin the board. It probably want cost you much dirhams.
