coolant problem
Coolant leak is very very dangerous bro, if it deplets too much overtime your car will overheat.
Start checking radiator bottle first, then follow the coolant thick hoses and see if can trace some leak. Then reach to radiator and check it nicely from top and bottom and then follow radiator big black thick hose to engine and see if its leaking from clamp (usuall spot).
