airlfilter change
There is no higher quality of Air filter comes, its just that performance air filter are less restrictive than the stock one OEM fitted one.
If you drive only on road then i can suggest K&N as its less restrictive and increases few HP and better MPG for your car and its long life filter, good for 100k kms.
Dont get K&N if you offroad then its not good as its oil based filter and will suck every sand and clog the filteration process even more.
  • 4 weeks later...
