too many problems at one time
Ok dear, sorry for your troubles. Lets do one step at a time.
Get a good electrician and ask him to check the wiring and trace where did short circuit happened. As due to this electrical short circuit AC fan must have switched off and car overheated and thrown all the coolant out of expansion bottle.
Your best bet to start with Engine main harness as you said all fuses are burnt so i am sure main wiring caught some earthing and starting blowing up all the fuses. Which is quiet weird and rare to see in Toyota's, they are good reliable car. Have you got some electrical job from aftermarket guys????? like music system, central lock, battery change or anything that involve fiddling with electrical wiring. Probably that guy you is the main root cause behind all this disaster.
Good luck dude.
  • 2 weeks later...
