break fluid is leaking of my Toyota
Let the proper mechanic diagnose it nicely following items for leak. Brake booster, brake master cylinder, brake pistons, brake caliper, brake fluid reservoir tank, brake line etc.
If still none found, then change the brake pad if its less than half. In some rare cases if brake pad is low and suppressing caliper too much that lower down the brake fluid level sensor to scream these message.
