Sticky gear to put in
Since last month my manual corolla having sticky 2nd gear to put in. Rest all gears are fine except the second gear, sometimes when i force to put in it makes grrr grrr noise and then i depress the clutch and try again it goes but with same difficult. Im clueless whether this is a gear issue or clutch or engine issue. Please advise, thanks in advance.
  • 2 months later...
Hi Kelum,
Hope your gear problem will be solved cause I believe i have a friend he is specialist in Auto Gear both in Manual and autotransmission. He could better solve out ur problem about gear.. coz i had repaired my auto gear from him and he is not charging a lot.. you may call him if u want ....
his number is 055 -4933386......give my reference name Moxx
thanks
