GTI 2008 DSG Gearbox change
Hello All,
My Gearbox seems to be broken, they told me in Nabooda Mechatronic issue.
I am trying to repair it is sharjah and find a used Gearbox. They told me it shall cost aroun 8000 AED.
can someone help me decide if it is ok to go for used gearbox or shall i pay 20000 and go to Nabooda!
I just pusrshased the car and i am so upset of this,.
thanks
Have you tried searching for someone who can rebuild the gear, that might cost less.
First google, if this mechtronic issue is due to age, then buying used one is risky.
If not, used one is good option but still check if rebuilding is doable and cheaper. That way you know it has good life and you will keep track of anything unsuall happening with gearbox in future.
  • 2 weeks later...
Gearbox usually dont fail so easily, if regular gear oil and gear oil filter get changed in time. What VW says gear oil is for life means life of gearbox and not car. And thats why they want you to spend money at 80-100k kms when gearbox fails. If gearbox oil changed at 30-40k kms these gearboxes runs over 250k kms easily.
  • 8 months later...
