dreamer Posted July 7, 2014 Report Share Posted July 7, 2014 I need to learn if one can do the wheel alignment on their own without a mechanical support from any workshop. Please share if we can. Link to comment Share on other sites More sharing options...
mohitmust Posted July 31, 2014 Report Share Posted July 31, 2014 Yes you can do it, but make sure you have done the wheel alignment before or atleast try to take help from an expert. You can do as follows: Firstly, you need to keep the front wheels of your car on jack stands. After doing that, activate you power steering by turning the car key to the ignition, but DO NOT switch on the car. Before starting, make sure that the steering wheel is at the center. To check the alignment you can use a straight broom. You need to adjust the broom in such a way that it’s between the fender edges of the wheel. Hold the broom properly and it will help you knowing the direction of the wheel pointing to. Either the wheels will be pointing inward or outward. Inward means that it is pointing towards the center of the car. Id f that’s the case, tightening the outer tie rod will help in aligning the wheel to the normal position. If it’s outward positioned, you need to loosen up the outer tie rod. Then move your wheel to the left, right and center position and check if it is aligned properly. Repeat the same procedure to the other frn end wheel. Not forget to tighten the tie rod before you finish. Take your car for the drive and check if the alignment is proper or not. Link to comment Share on other sites More sharing options...
dreamer Posted August 17, 2014 Author Report Share Posted August 17, 2014 Alright. will try it. Thanx bro! Link to comment Share on other sites More sharing options...
gshane Posted April 20, 2015 Report Share Posted April 20, 2015 I've used the help of a mechanic few days ago. Why would you avoid using a mechanic? The service is very cheap and you will know that your wheels and car in general is perfectly safe. Link to comment Share on other sites More sharing options...
