Check engine light
  • 2 weeks later...
The heck engine light occurs when there is any issue with the engine/emissions cotrol system. You cannot really judge whats wrong with your car only with the engine light on. The only way you can check is by using the scan tool. Scan tool helps in getting the trouble code, and then you diagnose the trouble code. Let me know what trouble code you get, i may help you with what is actually wrong and if its serious or a small issue.
