timing belt
But there are some cases that you need to take care about as well other than the manual description. First, if you think there is any fluid leak in the car, always get the timing belt checked as it may need to be removed. Second, the replacement interval of timing belt and water pump is almost the same, so you can get it replaced whenever you’re getting the pump replaced.
  • 10 months later...
As narang said, you should check the condition of your timing belt after 50.000 miles. But, you should definitely check it even before this mielage in case you drive your car "aggressively" (which is not a surprise when you have such a pwerful car).
