bomaint Posted May 30, 2011 Share Posted May 30, 2011 the break fluid is getting into the engine. how can i fix this problem and how is this happening Link to comment Share on other sites More sharing options...
farzaank Posted May 31, 2011 Share Posted May 31, 2011 There is practically no way that brake fluid can enter or leak into engine oil unless you pour it by yourself. If you see brake fluid level low and engine oil level high, its two different issues. Brake oil must be leaking and getting low. Check engine oil again twice or thrice for to be noted perfectly if its getting increased by time. If yes then it must be turning little milky liquid than oil because of leaking coolant from head gasket and hence also depleting the coolant level. Link to comment Share on other sites More sharing options...
