Replacement not covered?
pranav
Does the replacement of timing chain cover gasket is not included in the warranty. Recently, the dealer informed me that there was a leak from there and need a replacement. But it’s not covered in the warranty. Is it so? If yes, can I get it replaced from a local workshop as I am sure that the dealer will give me a big bill?
  • 3 weeks later...
Well any kind of replacement which is manufactured default is always covered in the warranty. If the leak is because of consumer fault, they generally don’t cover that in warranty. If you want it to get it replaced from local workshop, it’s a good thing and off course will be cheaper. But yes, the warranty from the dealer will for sure get void. You won’t be able to enjoy the free services or maintenance for free.
