Too much smoke
bradly
  • 3 weeks later...
I think the egine os overheated. Try to touch the engine dash, If you feel is too much heated then may be the engine is overheating. Its bad dude. Open the engine for a while and wait till it cools down. I think there is some leak in the engine. Check for the leaks using the smoke machine.
 Well I think is because of overheating. If your engine is too hot and there is smoke coming out, then yes it’s overheated. Cost of repairing it actually depends on from where the leak is. You might have to get some auto parts replaced.
  • 3 weeks later...
You guys were right i suppose. The radiator was too hot. I took the car to the dealer, and they said that the coolant was leaking. Don even ask the repair cost. They had to chage the head gasket and the radiator. :-|
  • 8 months later...
Doolant leaking can be a serious problem, It was a good idea to visit your dealer. This repair would've cost you much more in one month.
