Prado Cabin Noise
shahryar2002
Hi dudes,
Ramadan Kareem & Asalamoalikum to everyone,
Here I have another issue to be discussed with, regarding cabin noise on highway over 100 Km/Hr speed.
I thank you all in advance regarding the support and responses on my last post.
Although it's not too bad, but hard to differentiate in the video as per mic volume. Things worth checking are all door, windows and sunroof beading is intact and not broken or loose. Second do you have any sun deflector installed on any window or something install on roof to produce this hissing noise? Thirdly check your tire to choose good quality quieter HT tires as they also add the humming noise on highway.
if the car was banged then its worth to cheak that side sill seals too
Like danny said as it not too bad, because the Japanese cars focus too little on sound proofing unlike German or UK cars - different world altogether.
What I meant is, don't spend too much time and money in perfecting after all the basic checks are done.
I agree with Gaurav. Check the basics, seals, tires etc then forget about. You could spend a fortune dynamatting the whole car but there will always be a bit of road noise.
