my engine wont crank
cheveemee
my Chevrolet Captiva LS engine won't crank at all as if the battery dead flat.as this is the first thing that came out of my head so I check the battery with the tester and it's ok. However I notice the airbag warning sign blinks when I switch on the ignition key and it never happens before.
Have you tried jump start your car and its still same, then your starter motor (self) has died. If its manual gear car you can push and start. If AUTO then get it on recovery and send to workshop.
Airbag and other light stays on for 5 - 10 secs as a self check, i dont think its coz of that car is not starting. It happens so that you have noticed it today as when car is not starting. These all SRS, ABS, TC and other many lights come and go every time you start the car. Its there in all cars in the world. So its normal. Once car starts if it still stay then you need to worry. not now. Good luck.
