gear oil question
mahesh
If you got dipstick, you can check from it and also top up from same by specialized fuel station pressure funnel.
If no dipstick go under the car and open the top up bolt of gearbox and see if oil is level to the open bolt. If not, top up till it overflow and then tighten the bolt.
