Noise form the power steering is coming.
wassim
if you are confident abt the pulley then get it changed however the noise can be from power steering belt.
Its a age thing of the belt which has to be changed. For checking if its belt or the pulley, spray some wd40 on belt inside grooves and see if squeaking noise disappear, then change the belt not the pulley.
  • 7 months later...
