veel Posted February 29, 2012 Share Posted February 29, 2012 what is making my explorer to overheat. coolant is on the instructed level and now i am not sure what to do next. Link to comment Share on other sites More sharing options...
Shabir Posted March 22, 2012 Share Posted March 22, 2012 If coolant is fine and radiator is working i am assuming as your car hasnt exploded than it must be either AC fan (electrical one) or radiator fan (mechanical one) is faulty. Get both the fans tested with or w/o AC load and see if they are fine. Radiator fan also known as clutch or viscous fan that have two speed. One in normal speed and second one is hi speed that get to work once car started overheat little bit. In hi speed that fan makes hell of a noise. If your car starts overheat and you are not hearing that noise that means its time to change that viscous fan clucth. Link to comment Share on other sites More sharing options...
