Constant Popping/loud clicking sound when braking on reverse
I just noticed this on my Lancer GT 2015. Once I am backing up out of the parking, I can hear a loud popping noise while braking on the front end. Any suggestions what to check? I haf already changed the brake seals and lubricated things that needs to be, but still having this noise. Should i check other things (suspension, bushings)? Tie rod end and stab link are new also
I would advise to get the engine mounts and suspension checked. Does it only appear when braking while reversing ? And are you turning the steering wheel when this occurs ?
