battery is not charging
shael
when by battery was not charging i got it changed
but still the battery is not charging so i get the alternator checked which seemed good
now what
Jump start the car and remove the battery and see if car is running then that means alternator is fine. Then you can doubt the big battery fuse in fuse box 100 Amp something. There is no other thing to fail than battery and alternator, if you change the battery then it seems alternator for sure. but 1% doubt goes to fuse.
  • 3 weeks later...
