gear is not shifting into P
goodrider
no matter how hard i try i am not able to shit the gear into the P
what dose this mean, could it be the gear oil???
appreciate the advise
regards
It could be gear oil and bad filter. But before jumping on to oil, disconnect battery for 5 mins and connect back and try shifting to P if it goes it cold be electrical glicth and dont worry. Ford focus is quite notorious in these unexplainable electrical glicthes.
  • 10 months later...
my engine is facing the same problem not shifting out of P. checked the above things still the same
what should i d do next?
  • 1 year later...
I faced the same problem once. I went to the workshop and they changed the gear oil. He explained that sometimes the filter associated with the gear box gets damaged which in turn results into rough gear changing situation. It directly affects the smoothness of the gear change. I suppose you can start by changing gear oil and filter and see if this helps, or else look into professional gear builder who can diagnose the gearbox and recommend the repair work.
