how do i change fuel filter ?
ben
Fuel filter is usually located under the car near the fuel rail that comes from tank. If you go under the car you can locate it easily and change it too. Few positioning screws and hoses thats it.
Ok. Replacing fuel filters should be part of your regular maintenance. In case you don't know how to do it, please follow the steps:
1) Relieve pressure in the fuel system. (Make sure you do this for safety reasons)
2) Disconnect fuel lines.
3) Remove fuel filter. You usually need to unscrew the clamp holding it.
Note: Since you are at it, you might also want to replace the pressure washers.
