HOW IS THE AUTOMATIC LOCKING SYSTEM INSTALLED?
dylonclarkson
IF I HAVE TO GET THE AUTOMATIC LOCKING SYSTEM CHANGE WILL I HAVE TO GET THE DOOR LOCKS CHANGE OR THIS WILL BE SOME ADDITIONAL PART ON THE DOOR. WILL THEY HAVE THE MAKE HOLES OR HOW ARE THEY INSTALLED OTHERWISE.
  • 1 month later...
  • 7 months later...
  • 3 weeks later...
  • 2 months later...
Auto lock is very easy to install if car has come with central locking feature, then its only the auto lock box need to be installed and voila. If car is not having central lock then you need to install central locking mechanism in all door with proper wiring and then install auto lock box and configure everything with remote. In satwa irani guys can do only auto lock remote system from 100 dhs to 200 dhs. And if central locking is also needed then you can add another 100-150 dhs extra for that.
